1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Broken Seat
Old Mar 9, 2008 | 06:05 PM
BigBoy121988's Avatar
BigBoy121988
Default Broken Seat
my seat back is broken any ideas on how to fix??
Old Mar 9, 2008 | 06:22 PM
darkestxxnight's Avatar
darkestxxnight
Default RE: Broken Seat
get a new one
Old Mar 10, 2008 | 06:15 AM
PappiDread6's Avatar
PappiDread6
ORIGINAL: darkestxxnight
get a new one
LOL!!
Big Boy what is exactly wrong with you seats? Are they electric or power seats?
Old Mar 10, 2008 | 07:42 PM
noregrets's Avatar
noregrets
Big Boy, mine did the same thing. Dodge dealership told me I was sol (didn't even act like I could get another one). We have a bodyshop, so we tried to fix it on our own. First fix was to remove as much of the cover as we could (zipper under the back...get in the backseat and feel around under the seat and you'll find it). There are large holes in the seat itself. If you can find a piece of metal and slide it under to reinforce it and stabilize the seat and bolt it in using the holes that are already in the seat. I wish my husband had done this (which was my idea) but instead he wielded it. The seat is now lopsided and very uncomfortable (plus you have to use wielding blankets and such so you don't set the fabric on fire). If you can reinforce it, get another one (which I'm about to do myself). Go to www.car-part.com and find one.
Ang
Old Mar 10, 2008 | 08:18 PM
PappiDread6
I recently switch from electric to manual seats I still have the lower frame the motor works fine. I thought it was no good till I pull everything and vaccumed it was a small peice of dirt because after I vacummed the seat moved. [:@][:'(]
Old Mar 10, 2008 | 08:34 PM
PappiDread6
ORIGINAL: noregrets
Ang
WOW!! You did a hell of alot more than me. I just gut under the seat with a 1/4 rachet and unbolted the bottom seat from the frame. Unzipped the backin seat and took a 1/2 rachet and unbolted that from there the front two bots of the seat were easialy accessable. I already had a manual seat from the junk yard just had to swap cushions. Had to pay to have them refit the leather from my bottom seat onto the seat cushion from the manual seat. The only thing extra I did was pull the center console. But I was gonna bend the seat rails if the power seat didn't work.[:@][:'(]
Old Mar 11, 2008 | 12:36 AM
noregrets's Avatar
noregrets
Pappi, you know when you get 5 men in a bodyshop with a wielder staring at a problem they are going to find some way to use that wielder. I was the one who found the zipper and stuff on the seat when no one else seemed to be worried about it. When it broke I was very close to the dealership and so I drove it there. They didn't even seem to care even though I said I don't care what it cost to fix it. It just didn't look right for a short white woman to drive around with her seat laid all the way back. I realligned the seat (broke clear through the metal on the left driver's side seat), but found a few factory holes that would have been perfect to just fit a small plate in there to bolt it back in place. I even had the bolts picked out and had the drill in hand when the men decided their way would work nicely. I have a seat being held for me here locally....hope it matches up.
Ang
PS he did remove the seat last wknd from my son's venge venge seats are apparently made worse than camry door handles.
