1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
20" wheels on 96 avenger
Old Mar 15, 2008 | 05:48 PM
hardhittin's Avatar
hardhittin
Default 20" wheels on 96 avenger
what do i have to do to put 20" wheels on my 96 avenger and how much will it cost to do so.
Old Mar 15, 2008 | 06:22 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: 20" wheels on 96 avenger
20's WILL fit but they are way too big and cause clearance turning radius troubles ... It's way better to go 19's .... Cost depends on what wheels and tires you choose They will set you back at least $2000 Also with wheels that large UPGRADE BRAKES
Old Mar 15, 2008 | 06:54 PM
hardhittin's Avatar
hardhittin
I already have wheels and tires that are 20" but they will not fit what will i have to change on the car to make them fit and how much will it cost?
Old Mar 15, 2008 | 07:26 PM
darkestxxnight's Avatar
darkestxxnight
you probably have the wrong bolt pattern then
Old Mar 15, 2008 | 08:36 PM
bad venge's Avatar
bad venge
Section Moderator
Christ are we psychic ??? can you give us ANY information bolt pattern ???offset??? tire size ???
What kind of car are they off of ???
Old Jul 22, 2008 | 08:42 PM
victorv613's Avatar
victorv613
20's fit right in but i agree with venge turning radius will be trouble 18's or 19's. If yours dont fit it has to be a different bolt pattern than you have
