1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Bad Brakes?
Old Mar 17, 2008 | 08:26 PM
89daGuy's Avatar
89daGuy
Default Bad Brakes?
After driving home from work today, I noticed a weird smell once I got out of the car. I looked around and noticed my Front Passenger side rim was steaming. I took the tire off to check out the brake, and burnt my fingers of the lugnuts.
So, any ideas on what may be making my brake heat up so much? My friend suggested a bad bearing or a partly jammed brake. But I'm not sure.
Old Mar 17, 2008 | 08:54 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: Bad Brakes?
likely the calipers sticking
Old Mar 17, 2008 | 08:59 PM
89daGuy's Avatar
89daGuy
Thanks bad venge
Anyway I could fix/check that myself? Or should I just take it to a shop?
Is it even safe to drive to the shop?
Old Mar 17, 2008 | 10:13 PM
darkestxxnight's Avatar
darkestxxnight
if you have mechanical skills its not hard at all to replace a caliper if that is the problem.
Old Mar 17, 2008 | 10:19 PM
bad venge's Avatar
bad venge
Section Moderator
Remove the caliper and use a C clamp to depress it back into the housing if it moves smothly then loosen up the clamp and try hitting the brakes and watch the movement if it comes out and then returns back it's OK ... I've also seen the caliper pins being too dry (not lubed) cause similar troubles ...
If it's the caliper you can buy a rebuilt one fairly cheap
Old Mar 18, 2008 | 10:45 AM
Sroufe7's Avatar
Sroufe7
Jack it up and try to spin the wheel. If the wheel spins, step on the brakes and release them and try to spin the tire again.
If it gets are to spin after you hit the brakes with the caliper or brake hose is bad.
Take off the rim and unbolt the caliper.
Get something to push the caliper in, if it is hard to push in, open the bleeder and if it is still hard to push in the caliper is bad, if it goes in easy after you open the bleeder the line is bad.
Either way if you are interested in upgrading your brakes to GSX, let me know, we sell a complete bolt on package. We also sell stainless steel brake lines.
Old Mar 18, 2008 | 11:14 AM
josef15111's Avatar
josef15111
i need just the front calipers for the gsx well the brackets too i need a pair of loaded front calipers for gsx swap how much you charge for them???? i allready have the larger rotors drilled and sloted with ceramic pads...
JOe
Old Mar 18, 2008 | 11:17 AM
Sroufe7's Avatar
Sroufe7
ORIGINAL: josef15111
JOe
Here you go.
http://www.disturbingmotorsports.com...roducts_id=364
