1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Oil in my anti-freeze...help!
Old Apr 3, 2008 | 07:35 PM
Sweet Avenger's Avatar
Sweet Avenger
Default Oil in my anti-freeze...help!
I have an avenger 2.0 5 speed and for the past week I've been getting oil inmy enginecoolant resevoir. The oil doesn't go through the radiator though. I believe it is the headgasket but am not sure. Let me know my options.
Old Apr 3, 2008 | 07:42 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: Oil in my anti-freeze...help!
Headgasket or cracked head
Old Apr 3, 2008 | 07:48 PM
Sweet Avenger
I need to get another month out my car then i will fix it right but until then would i be able to add a temporary fix like Bar's Leak or some other type.
Old Apr 3, 2008 | 08:05 PM
bad venge's Avatar
bad venge
Section Moderator
Bars leak is low pressure radiator leaks it will not hold the higher pressure of the head/headgasket
Old Apr 3, 2008 | 08:10 PM
Sweet Avenger
Is there anything i can add to temporarily fix it. It is only driven on the weekends for a total of about 90 miles. What would a round about price be to fix the headgasket and/or head.
Old Apr 3, 2008 | 08:27 PM
crazykane's Avatar
crazykane
does it get hot? if not drive it. if its getting oil in the water it should get water in the oil. your oil will look milky
Old Apr 3, 2008 | 08:30 PM
Sweet Avenger
No the car doesn't overheat at all. I have to change the oil this weekend so i will check that out.
Old Apr 4, 2008 | 06:28 AM
PappiDread6's Avatar
PappiDread6
ORIGINAL: Sweet Avenger
Hold up is there coolant in your oil as in you have a white milky sumbstans on your oil dipstick and/or under your oil cap? Or the oil is in your coolant resivior bottle like in the pic below?
[IMG]local://upfiles/40445/C83B965156F54B1286D96A5ED5A66DA9.jpg[/IMG]
Old Apr 6, 2008 | 06:46 PM
yanickee's Avatar
yanickee
If it is your headgasket (sounds more like it), I would not drive the car or you will destroy your engine!
