1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
97+ headlight conversion
Old Apr 18, 2008 | 05:37 PM
rednekkracer's Avatar
rednekkracer
Default 97+ headlight conversion
I have a 1996 Dodge avenger and wish to do the conversion over to 97+ headlights I was wondering if it is possible and how to go about it. Thanks in advance for any help
Old Apr 18, 2008 | 06:41 PM
darkestxxnight's Avatar
darkestxxnight
Default RE: 97+ headlight conversion
buy 97+ headlights and a 97+ front bumper and put them on your car.
Old Apr 18, 2008 | 07:00 PM
bad venge's Avatar
bad venge
Section Moderator
You'll also need 97+ turnsignals , and foglights if so equipped...
It's an unbolt/unplug/ rebolt replug in ...
Old Apr 18, 2008 | 07:24 PM
rednekkracer
Thanks guys wasn't sure if I had to buy the 97+ bumper or not but I guess I'll just wait until I get my body kit then do it. Will be easier that was won't have an extra bumper cover to have sitting around
Old Jul 26, 2010 | 10:51 PM
jeepfreek's Avatar
jeepfreek
Not trying to dig up an old and obsolete thread but I'm new here. I just picked up a '95 Avenger from a bodyshop (customer lost intrest or cash?) for a reasonable $350! It seems that the owner decided to save some money and strip the car for paint but broke the tabs on both headlamps and 1of 2 fog lights! These lights are getting hard to find! I see that your changing the bumper cover, fogs and turn signals to do a swap but is there that much of a differance? It loks to me (by part numbers) the aftermarket bumper covers and fenders all use the same parts regaurdless of what year? Isn't the only differance that the 95-96 ones have those silly horizontal lines on them and the 97-00 have the claer lenses? If this is true wouldn't you just change in pairs to whichever you like the most?
Am I wrong or right?
Old Jul 27, 2010 | 05:35 PM
bad venge's Avatar
bad venge
Section Moderator
wrong front bumper covers are different the 97+ are pointier at the bottom , the headlights are a different shape they jut out 1/2" further in the middle
Also the fogs are different shaped as are the turns
Old Jul 28, 2010 | 12:24 AM
jeepfreek's Avatar
jeepfreek
Then if I I buy a body kit what Headlights Would I use? they use the same part numbers for all years 95 to 2000?
Old Jul 28, 2010 | 05:05 PM
bad venge's Avatar
bad venge
Section Moderator
I see different numbers for 95/96 and the 97+ most body kits are 97+
Old Jul 28, 2010 | 05:49 PM
jeepfreek's Avatar
jeepfreek
You see different #'s for what? The lights or the body kits? Extreme Dimensions only lists one part # for a front bumper per style? If I want to through on the Viper style facia on my 95 there # is ED1401. I do see a different # for the rear lip which i assume is the rear facia for 95-96 and 97 up, not sure what the difference is there?
Old Jul 28, 2010 | 08:00 PM
bad venge's Avatar
bad venge
Section Moderator
HEADLIGHTS have different numbers as mentioned most kits are 97+ there are several that are year specific
