1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Car Revs Itself
Old Apr 28, 2008 | 08:40 PM
venge96's Avatar
venge96
Default Car Revs Itself
Hey guys,
I had a couple of questions about my avenger. When i am driving down the road the rpm's on the car are fine but when i come to a stop its like the rpm's rev up and down by themself, like say from 1000 rpm to 1400 rmp, and after a few seconds of this it evens out...???!!!! What could be going on here....ive heard many things ...iac...manifold leak...o2 sensors...? Also, can i take it to say an autozone and have them check the computer to see what is wrong? Finally, if any of you have any estimates on how much each of the parts in question would cost...i would greatly appreciate it. Thanks Again..
Old Apr 28, 2008 | 08:58 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: Car Revs Itself
I'd go buy a bottle of Seafoam and clean the intake ... It might just be a dirty IAC
Old Apr 28, 2008 | 10:01 PM
venge96's Avatar
venge96
Thanks a bunch...by the way ....... whats the best way to go about doing this?
Old Apr 29, 2008 | 08:22 AM
PappiDread6's Avatar
PappiDread6
Here https://dodgeforum.com/m_655972/tm.htm
I think you suck 3/4 up into your intake and the rest go in your gas tank. Then you have to change you oil after a couple hundred miles to get all that out.
Old May 1, 2008 | 01:08 PM
spdracr's Avatar
spdracr
Try bad venge's cleaning first just to see what happens (cheaper too), but I had the exact same problem so my money is on a blown intake gasket.
Hope that helps!
