1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
glue like substance?
Old May 20, 2008 | 05:39 PM
dynamiteplaya3's Avatar
dynamiteplaya3
Default glue like substance?
was working on my car today and noticed a Brownish gluelike substance under the car splattered all over like the CV joint & surrounding.. this is not happening on the other side. its not mud i can tell ya that lol it smells like a lubricant but i really just dont know. i no my struts are bad and need replaced, could this be a leaky strut or CV joint.. i really cant pinpoint where it is coming from since it is just randomly splattered around.
Old May 20, 2008 | 07:05 PM
disturbingavenger's Avatar
disturbingavenger
Junior Member
Default RE: glue like substance?
One of your cv joint boots has a hole in it
Old May 20, 2008 | 07:20 PM
dynamiteplaya3
is that a bad thing???? like does it need replaced or is it ok to drive it like that????
Old May 20, 2008 | 07:47 PM
bad venge's Avatar
bad venge
Section Moderator
It's likely the lube from around the CV joint ... You can drive it but it CAN/WILL damage the CV joint/axle assembly ...
You can get a new boot for around $20/$30 The Axle with boot will set you back $100/$150
Old May 20, 2008 | 08:41 PM
dynamiteplaya3
ok.. is the boot an easy do it yourself fix or shop recommended.. my grandfather is really good on cars, just doesnt have the time to help me work on it cause hes always at work. so if i can find some time i will take it over to him to fix so i can stay away from labor fee's
Old May 21, 2008 | 07:08 PM
dynamiteplaya3
lookin at autozone website and lookin at boots... whats the difference when it says Inner and Outer is there 2 diff boots im guessing.. which one do i need??
Old May 21, 2008 | 07:24 PM
bad venge's Avatar
bad venge
Section Moderator
Looks like the outer boot (closest to wheel)
