1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
front hub [bearing] replacment
Old May 27, 2008 | 04:06 PM
scatpackmopar's Avatar
scatpackmopar
Default front hub [bearing] replacment
Is there a wy to remove the front hub [passneger side] without removing the axel? The 4 bolts are behind the C/V joint making them almost impossible to get to without removng the C/V joint. I was going to try a crow foots socket but thought I would ask if anyone has done it before without removing the axel. I want to replace the axels but I have never done them before. Are they an easy swap?
Old May 27, 2008 | 10:25 PM
master tech's Avatar
master tech
Site Moderator & Tech
Default RE: front hub [bearing] replacment
Yes, Remove the axle nut and push the outer CV joint back so you can remove the bolts. Then slide the bearing assy off.
