1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Noise while accelerating 1998 avenger
Old Jun 29, 2008 | 02:31 AM
Laynlow's Avatar
Laynlow
Default Noise while accelerating 1998 avenger
Hi all Im back with more questions, My 1998 Avenger seems to be making a high pitch niose when I accelerate going over 80 km everytime I touch the throttle it kicks in then when I tap it it goes and comes as I do it. Does anyone have any clue on what would cause this.
Any help would be great
Cheers!
Old Jun 29, 2008 | 07:46 AM
PappiDread6's Avatar
PappiDread6
Default RE: Noise while accelerating 1998 avenger
Is it a squeeling sound or a high pitch whinning sounds?
Old Jun 29, 2008 | 08:59 AM
bad venge's Avatar
bad venge
Section Moderator
Does it change pitch when accelerating ???
Old Jun 29, 2008 | 10:13 AM
Laynlow's Avatar
Laynlow
it is a high pitch whinning noise, and it does not change when accelerating it only starts when you touch the throttle go over 80 k
Old Jun 29, 2008 | 10:30 AM
PappiDread6
by Whinning sound I mean the sound you hear when you turn your steering wheel too far all the way right or left. Also in some case people who do their own aftermarket stereo setup they having whinning sounds that get higher and lower when accelerationand decelerating.
Check the color and level of you powersteering fluid, also check for leaks,and if you have an aftermarket stereo set up I would check the wiring.
Just for kicks turn your steering wheel all the way left or right and snap the throttle to see if the noise is duplicated that way. Also try it in Drive gear and hold the brake.
Old Jun 29, 2008 | 10:54 AM
Laynlow's Avatar
Laynlow
it sounds Very much like a incorrect installiation of a stero, but it is not the case it sounds like it is coming from just on the other side of the firewall and it sems to have nothingto do with the steering as I can crank the wheels in park and dont hear a thing.
Old Jul 24, 2008 | 11:57 PM
Laynlow's Avatar
Laynlow
could this be somthing to do with the ball joints or bearings?? please help
Old Jul 25, 2008 | 12:18 PM
bad venge's Avatar
bad venge
Section Moderator
usually bearings the noise will increase as speeds increase ...
Old Jul 25, 2008 | 03:15 PM
Laynlow's Avatar
Laynlow
but would the noise stop as soon as throttle is de-pressed, it seems to only do it going over 80 km then if I stop touching the gas even goinig 120km the noise stops
Old Aug 13, 2008 | 08:27 AM
Serenity97's Avatar
Serenity97
Junior Member
If it means anything, I've noticed a similar noise. It been doing it for the 2 years I have had it but besides being kind of annoying it doesnt seem to be having an impact on the drivability.
