1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
engine swap
Old Jul 15, 2008 | 08:52 PM
mark1267's Avatar
mark1267
Default engine swap
I currently have a 97 es with a 2.5 and automatic trans., will a turbo 3.0 from a 97 3000GT fit in like the other 3.0's that you guys have told me about? and/or could the use of a turbo 4cyl. be a large enough power increase to make up for the cost and labor involved in the swap? if neither, could a 3.0 have an aftermarket turbo attached and still fit properly?
I just don't want to do all the work and not really see the difference in power.
Thanks in advance for the input
Old Jul 15, 2008 | 09:03 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: engine swap
NO ... the 3000gt will not fit totally different motor ...
The 4 cyl turbo is a possibility but the cost of the turbo kit or the donor turbo car might be more then the venge is worth ...
3.0 has a supercharger kit available from rippmods
Old Jul 15, 2008 | 09:09 PM
mark1267's Avatar
mark1267
do you have any idea what type of power increase would a 4 cyl turbo give over the 2.5 and would the tranny bolt up? I may be able to get the turbo motor for a good price
Old Jul 16, 2008 | 01:05 AM
mark1267's Avatar
mark1267
is the 3.0 that is needed a 6g72?
Old Jul 16, 2008 | 12:12 PM
bad venge's Avatar
bad venge
Section Moderator
ORIGINAL: mark1267
What motor /car ???
Old Jul 17, 2008 | 12:07 AM
master tech's Avatar
master tech
Site Moderator & Tech
bad venge
Would the 3.0L out of a mini van work?? They both are by mits. Or is the engine too tall for the enginecompartment.
Old Jul 17, 2008 | 10:50 AM
bad venge's Avatar
bad venge
Section Moderator
THe 3.0's we KNOW work are the Eclipse , Galant and Strat ... Unsure on the Minivan if it is the 6g72 or not
https://dodgeforum.com/m_825780/tm.htm
