95 Avenger Starts but sounds like it flooding when put in gear?
1995-2000 Dodge AvengerThe Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
I can start her just fine. It also idles just fine. Just once you give her gas it starts to bog down. If you put her into drive it is choking for air. If you let up on the gas pedal and tap it a bit you can move forward but that is about it.
I replaced this and now able to get to 40 mph but engine now idles roughly. Now looking at the throttle opening it seems to work when I press the gas. I wonder if that is bad. Since now I am getting radical idle now?
Should the intake flap that allows air to come through open by itself when at Idle? I did notice that mine is staying closed. What do you think. I will run some sea thru the system.
i have the same problem with my 98,did u solve your problem,at the moment i'm trying the main distributor,will get my answer when the garage installs it,was doing the same as yours,rough idle ,if u pressed gas it would stall
