1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
HVAC Light / Cruise Control
Old Aug 13, 2008 | 10:59 PM
wballa's Avatar
wballa
Junior Member
Default HVAC Light / Cruise Control
Hey,
Where do you find the bulb which illuminates the HVAC controls at night ? Pulled the trim piece out around the controls but did not find the bulb.
Also, my cruise control turns on and I am able to set the cruise and the "cruise" light does come on but, it does not control the speed of the car. It thinks it's working but it is not.
Thanks in advance.
Old Aug 14, 2008 | 12:30 PM
bad venge's Avatar
bad venge
Section Moderator
bulb is on the center rear of the hvac ... if you have skinny hands you can reach up and find the plug and untwist it ...
Cruise ...do your brake lights work right ???
Old Aug 14, 2008 | 05:38 PM
wballa's Avatar
wballa
Junior Member
HVAC Light - I will check it out thanks.
Cruise - Yes, the brake lights are fine
Old Aug 15, 2008 | 06:00 AM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
I think BV is saying that the brake switch may be faulty. If that switch is bad, it will disengage the cruise and if that happens the cruise light won't come on. You could be having issues with the piece in the engine bay that moves the throttle cable.
Old Aug 15, 2008 | 06:32 AM
wballa's Avatar
wballa
Junior Member
The point is the cruise light does come on therefore I assume it is not the brake light switch.
Looking under the hood, I see what appears to be the throttle cable going through a black box, I assume this is the cruise control unit ?
Old Aug 15, 2008 | 06:36 AM
silvercoupe97
Uber Moderator
Yup. Do you by chance have a junk yard around you with Avenger/Sebring/3G Eclipse cars in them?
Old Aug 15, 2008 | 11:35 AM
wballa's Avatar
wballa
Junior Member
Not sure, haven't checked the junkyards yet, you suggesting I need a new black box under the hood ?
Old Aug 15, 2008 | 12:09 PM
bad venge's Avatar
bad venge
Section Moderator
I had a bad brake light switch , my cruise light stayed on but wouldn't hold speed ... After awhile I noticed the brake lights were staying on... The switch wasn't returning
(bad internal spring)
Old Aug 15, 2008 | 04:48 PM
silvercoupe97
Uber Moderator
You may, but I would do BV's suggestion first as those switches are constantly beat on and are more common to go bad over the CC junction box.
