1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
OBD II Code Question
Old Nov 4, 2008 | 01:39 PM
1997avenger's Avatar
1997avenger
Default OBD II Code Question
I have a 1997 Avenger ES. The check engine light came on so I went to Auto Zone and the tech plugged in an OBD II unit which came up with codes P0700 and P1768. If someone could give me information on what these codes mean in regard to my Avenger I would appreciate it.
Old Nov 4, 2008 | 06:18 PM
bad venge's Avatar
bad venge
Section Moderator
Autozone should gave you a printout ... I only have the 2 digit codes , no way for me to get those at this time
Old Nov 4, 2008 | 07:01 PM
1997avenger
Default AutoZone Printout
AutoZone did give me a printout of the codes, however, the definitions for the two codes are not for dodge vehicles.
Old Nov 4, 2008 | 07:16 PM
bad venge's Avatar
bad venge
Section Moderator
What is their "notations" ???
Old Nov 4, 2008 | 07:41 PM
1997avenger
Default Notations
On the P1768 it has something for Honda, Isuzu, Acura, and Volkswagon. On the P0700 it has something for those and Chrysler which is about the transaxle control system fault which I wanted to double check since it's not specific to the Avenger. But there is nothing dodge related on the P1768...
Old Nov 5, 2008 | 05:52 AM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
Our forum has a few, but that P1768, it doesn't.
https://dodgeforum.com/forum/general-tech/15042-service-engine-codes-for-obd-ii-engines.html
Do the keydance so that you can get a generalized area.
https://dodgeforum.com/forum/general-tech/8717-service-engine-codes-for-obd-engines.html
...or look at the "P" codes from here.
P1768
Performance / Normal / Winter Mode Input Malfunction
http://www.troublecodes.net/OBD2/Pcodes.shtml
From that, it could be a PCM/tranny issue, or even something as simple as the fluid...remember, that the A604 is finicky and only agrees with MOPAR/Mitsu tranny fluid. Don't settle because of price.
So, as you can see, there is a transmission issue. Whether it be electrical or mechanical is hard to tell from here as we know nothing about your car, so you'll have to give us some more info about the tranny.
Any other ideas BV?
Old Nov 5, 2008 | 11:21 AM
1997avenger
Default Car Info
I just bought the car a little while ago so I don't know a ton about it. It has the 2.5L engine, and the transmission acted fine before but now it won't go into o/d. It still runs smooth in the lower gears but when I push the o/d switch it says it's off or on but it's the same-no o/d. I'm probably going to get a diagnostic that's a little better than AutoZone...
Old Nov 5, 2008 | 12:21 PM
bad venge's Avatar
bad venge
Section Moderator
This will sound weird .... But do you have back up lights ??? No backup lights check the fuse , the fuse also supplies the O/D circuit
Old Nov 5, 2008 | 12:44 PM
1997avenger
Default Backup Lights
I'm not driving the car today so I'll have to check after work. Thanks for the suggestion.
Old Feb 25, 2010 | 11:33 PM
Julissa's Avatar
Julissa
sounds good to me..
