1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Avenger door locks
Old Feb 8, 2009 | 07:54 PM
fil327's Avatar
fil327
Default Avenger door locks
I have a 1999 es Avenger and on several occasion when I leave the doors unlocked the car will lock the doors. I dont think its suppose to do that because it doesnt do it every time. So today I drove around the block got out and stood by the car for about 3 minutes and "click" the doors lock by themselves, tried it again and "click" it did it a second time,but when I trieds it a third time it didnt do it. Any one have any ideas on what is going on here. Thanks in advance.
Old Feb 8, 2009 | 08:27 PM
bad venge's Avatar
bad venge
Section Moderator
Factory Alarm system ???
There is a switch attached to the key in the door the switch gets flakey
Aftermarket Alarm ????
Bad relay/bad brain
Old Feb 9, 2009 | 10:52 PM
fil327's Avatar
fil327
Factory alarm, and I dont understand "switch attached to the key in the door the switch gets flakey" Please to explain and is there a fix. Thanks again.
Old Feb 10, 2009 | 08:48 AM
bad venge's Avatar
bad venge
Section Moderator
There is a Switch if you remove the inner door panel drivers door then follow the key lock mechanism there is a small switch with a wire going to it /order a new one $10 or so and replace it
Old Feb 10, 2009 | 08:21 PM
fil327's Avatar
fil327
Should I replace both sides driver and passenger or just driver and thank you.
Old Feb 10, 2009 | 08:51 PM
bad venge's Avatar
bad venge
Section Moderator
Not positive , thought it was in drivers door only
Old Feb 10, 2009 | 10:02 PM
fil327's Avatar
fil327
One last thing,did u replace ur factory front dash speakers in your car and if so what brand and model did u use. What did u use for the door and rear dash speakers also, thanks
Old Feb 11, 2009 | 09:14 AM
bad venge's Avatar
bad venge
Section Moderator
The easist direct replacement for the dash are the Bose 301,501,601,901 tweeters :
http://cgi.ebay.com/OEM-BOSE-3-1-8-R...3A1%7C294%3A50
is what I use ...
I'm running Focal Utopia series components in the door and Eclipse point source in the rear deck
