1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Camshaft Sensor Failure?
Old Feb 22, 2009 | 07:46 PM
candacebadie's Avatar
candacebadie
Default Camshaft Sensor Failure?
For starters I've got a 1996 ES 2.5L V6
I was driving on the expressway when suddenly the car started surging and the check engine light came on and the car died on me. After being towed off the Eway and waiting for an hour I was able to drive it home which was maybe a mile away. They put the OBD scanner on it and it read P1391 and AutoZone gave me a print out for the camshaft sensor. Which brings me to my questions
I was wondering if the camshaft position sensor is independent in my car or would I have to replace the whole distributor?
Could this be an overheating fuel pump?
Could this affect the timing/ would I need to have the timing belt done again if it stretched or jumped?
Old Feb 22, 2009 | 08:40 PM
bad venge's Avatar
bad venge
Section Moderator
The CPS is a hall effect sensor and YES it can fail with no warning ...
It is a seperate part , that is reletively cheap and easily replaced ...
NO it has nothing to do with an overheating fuel pump ...
NO it will not effect/damage/change timing
Old Feb 22, 2009 | 09:54 PM
candacebadie
Could you briefly describe where it is, because I was told that only the I4 DOHC have an independent sensor and that's why I couldn't buy one and I would need the entire distributor because it is incorporated into the distributor for the V6's
Old Feb 23, 2009 | 12:22 AM
bad venge's Avatar
bad venge
Section Moderator
https://dodgeforum.com/forum/diy-do-...bad-venge.html
Old Feb 23, 2009 | 07:53 PM
candacebadie
I believe that this is how you test the crankshaft sensor, because I see nothing near the top of the trans that looks like what I purchased from AutoZone, Is the end opposite the socket on the cam sensor housed in the engine?
Old Feb 23, 2009 | 08:54 PM
bad venge's Avatar
bad venge
Section Moderator
I'm not following the question ...
Old Feb 26, 2009 | 02:52 AM
candacebadie
http://images.google.com/imgres?imgu...%3Den%26sa%3DN
Where exactly is the sensor located in relation to the distributor cap?
Old Feb 26, 2009 | 09:29 AM
bad venge's Avatar
bad venge
Section Moderator
crank sensor is mounted on the tranmsission in an area just below the distributor
cam sensor is mounted near the battery tray
Your Title says Camshaft sensor , the part you have is the Crankshaft sensor So I'm a little confused as to WHAT you want to replace
Old Feb 26, 2009 | 04:31 PM
candacebadie
I DO want to replace the Camshaft Sensor NOT the Crankshaft sensor, the piece they sold me looks just like the one in the link, that's probably the mix up because I was under the impression that that was the Camshaft sensor, could you point me to a picture of the camshaft sensor?
Old Feb 26, 2009 | 05:29 PM
bad venge's Avatar
bad venge
Section Moderator
They LOOK the same , Unsure if they are interchangeable , The link States its a Crank sensor :
http://www.1aauto.com/1A/CamshaftPos.../Dodge/Avenger
