1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
engine shaking, rough idle?
Old Sep 29, 2011 | 12:26 PM
lariders's Avatar
lariders
I am having the same problem with my car. It is a 1995 intrepid. It has a rough idle that started a few months ago and it gets a little worse when put into gear. The car runs and drive fine. Only the idle is the problem. I don’t know a lot about dodges. So any help would be great. Thanks
Old Sep 29, 2011 | 04:25 PM
bad venge's Avatar
bad venge
Section Moderator
It's like any other Dodge , Clean Intake with Seafoam , Throttle body , ect.
After that remove the IAC and clean it. If that doesn't help block the EGR and see if the idle smooths out.
You have to verify that the spark is consistant
Old Sep 30, 2011 | 09:16 AM
lariders's Avatar
lariders
How do I block off the egr? I have done plugs and wires, about 6 months ago as PM. I have not done the sea foam yet, but was going to soon. what is the best way to get everything clean? I was thinking about letting some suck into a vaccum line.
Old Sep 30, 2011 | 04:05 PM
bad venge's Avatar
bad venge
Section Moderator
I DO NOT have your car so can't say the best way to block the EGR usually I use a gasket cut to shape where it feeds into the intake
yes the vac line feeds in the best
