1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Little tranny question/problem??
Old Mar 26, 2009 | 01:26 PM
JLA74's Avatar
JLA74
Default Little tranny question/problem??
I have a problem with my auto (98 venge 2.5 automatic). Everytime I slow down and turn or accelerate from around 20-35 mph I hear this clunck in the front left. I have replaced the front struts/mounting hardware, axles, and joints. Replaced the front motor mount and inspected the others. My noise is most noticeable when I slow down to turn and then put on a little gas and the clunk occurs. Always in the front left and very repeatable. One thing I did notice is if I manually shift into 2nd when slowing and preparing to corner and then D after accelerating it doesn't do it. It seems to me that tranny isn't going into 2nd gear on the down shift. Is this possible? If so any ideas?
Old Mar 26, 2009 | 06:50 PM
bad venge's Avatar
bad venge
Section Moderator
Have you had the recall on the ball joint lower arms done ???
Have you checked the Hub assembly /bad bearings ???
Old Mar 27, 2009 | 09:14 AM
JLA74's Avatar
JLA74
I had the recall done about two months ago and I replaced both hub assemblies last fall.
Old Apr 2, 2009 | 11:41 AM
JLA74's Avatar
JLA74
Anyone have any other suggestions??
Old Apr 2, 2009 | 12:55 PM
COYOTE102076's Avatar
COYOTE102076
Not really an answer, but just a thought: Is the transmissions on these cars computer controled or mecahnicaly opperated?
If it was computer controlled, may be a bad speed sensor or an electrical conector dirty?????
If it is mechanicaly controlled, possible to have a vaccume leak? Or kick down cable out of adjustment???? I know on Chevy trucks, the kickdown cable can get out of adjustment and cause all kinds of goofy stuff to happen. ( Also known as the Throttle Valve cable, or most commonly called simply the TV cable! lol. )
Like I said, not an answer. Just something to think about.
Old Apr 9, 2009 | 11:45 AM
JLA74's Avatar
JLA74
I guess I can't answer any of your questions but I think it's all electronic. One other thing I was wondering is if there is a shift selonoid that may be controlling the down shift?
Old Apr 12, 2009 | 12:12 AM
master tech's Avatar
master tech
Site Moderator & Tech
Yes. there is a shift solenoid, but not inside the trans. Its called a solenoid pack. You may want to have a DRB3 hook up and ck for trans codes and the CVI's too.( Clutch Volumn Index ). Your clutch pack could be causing your clunk.
Old Jun 8, 2009 | 04:24 PM
JLA74's Avatar
JLA74
Is this something I need to go to a tranny shop to do? Or can I do the scan at an autozone or something?
Old Jun 9, 2009 | 12:06 AM
master tech
I don't know if a trans shop or autozone has the cables to hook up to both connectors.
Old Jan 4, 2012 | 07:15 PM
JLA74's Avatar
JLA74
Well a little more info after driving and making some more repairs over the last year. The cluncking noise is-was coming from the rear lower control arms. The tranny doesn't seem to want to shift out of overdrive automatically unless I come to a complete stop. When I slow down for a turn and manually take it out of overdrive using the button on the shifter it work fine. What controls the overdrive down shift??
