1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Suspension question
Old Apr 9, 2009 | 01:01 AM
candacebadie's Avatar
candacebadie
Default Suspension question
How can you tell if I need new struts/mounts or if the rattling noise I hear when I hit a small bump is the sway bar links. I don't hear it all the time and the suspension is pretty tight (not bouncy) when I press up and down on the front end
Old Apr 9, 2009 | 11:42 AM
JLA74's Avatar
JLA74
How many miles are on the car/suspension now. If there are over 80K you are most likely in need of new struts anyways regardless of the bounce. I replaced mine at 110k and should have replace the coil spring at the same time because I still have the knock when I hit a bump on the left front.
Old Apr 9, 2009 | 03:38 PM
candacebadie
Mines got 110K on it too, guess O'Reilly's it is!
Old Apr 9, 2009 | 08:53 PM
bad venge's Avatar
bad venge
Section Moderator
Inspect the bushings first ... the A arms , the sway bar mounts ect they can be wore and rattling , also inspect the strut mounting the rubber can be shot as well
