1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Avenger Infinity Amplifier Fuse?
Old Apr 20, 2009 | 03:40 PM
metaljer's Avatar
metaljer
Default Avenger Infinity Amplifier Fuse?
I have a 99 Avenger with the factory Infinity MR158403. I had the alternator replaced and then the radio didn't work. I replaced the fuse (under the hood) and the radio worked but there was no sound. I figured there was a fuse for the amp (there is, under the driver's side dash, but it wasn't blown.) Then I bought another Infinity amp, but it didn't make a difference: No sound.
Any ideas?
Old Apr 20, 2009 | 08:46 PM
bad venge's Avatar
bad venge
Section Moderator
check the large gauge red wire and the white wire with black/silver dots for 12 volts on the amp
Old Apr 22, 2009 | 12:18 PM
metaljer's Avatar
metaljer
Okay, no power. Is there a fuse?
Old Apr 22, 2009 | 10:43 PM
bad venge's Avatar
bad venge
Section Moderator
No power on either ??? there is no fuse on the white with black/silver dots
