1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
What are the specs on the factory infinity system?
Old Apr 26, 2009 | 10:02 PM
mosgangstarr's Avatar
mosgangstarr
Default What are the specs on the factory infinity system?
What does the head unit push?
What about the amp?
And what are the specs on the stock speakers?
And are the door speakers 6.5 or 6 3/4? .every site i check says 6.5 but iv'e heard some say they're 6 3/4.
Would these work well with the stock amp?
http://www.onlinecarstereo.com/CarAu...roductID=19729
http://www.onlinecarstereo.com/CarAu...roductID=19624
Old Apr 27, 2009 | 08:52 PM
bad venge's Avatar
bad venge
Section Moderator
Here are the specs ,,,
6 Channels 26 watts RMS at 4 ohms from the amp
I've never found a rating on the head unit
The doors are 6 3/4" but the 6 1/2s are a good fit as well
Here's the trouble , the amp has crossovers and will not feed highs to the doors as it's split at the amp and splits to the tweets and the door
the BEST way to go is the component set and skip the component crossover
Old Apr 28, 2009 | 09:07 AM
mosgangstarr
Do you think i might be able to get some 6x9's to fit in the door?
Old Apr 28, 2009 | 12:01 PM
Killa200's Avatar
Killa200
not without a decent amount of metal removal. I'd just spring for a pair of good 6 3/4's or 6 1/2's. May just be my ears but they sound better up front than oval type speakers
Old Apr 28, 2009 | 09:34 PM
bad venge's Avatar
bad venge
Section Moderator
unless you get slimline 6X9's (the bass will suffer) the window will interfere with depth
Old Apr 30, 2009 | 08:52 AM
mosgangstarr
How well would infinity perfect 6.1 componenet work with the stock amp?
Would the tweeter that comes with them fit in place of the stock one in the dash?
If so how hard is the dash to take apart?
Old Apr 30, 2009 | 11:02 AM
Killa200's Avatar
Killa200
the front dash speakers will just pop out without even needing to mess with the dash. They are either 3" or 3 1/8th", can't remember off the top of my head. What i do remember is they are a pain to find a replacement for.
Old Apr 30, 2009 | 12:13 PM
robertwyoung's Avatar
robertwyoung
Default I-Mount Starfish
I used the I-Mount Starfish and some epoxy to mount my tweeters to the stock grills.
I'll post some pictures later I'm at work and they are on the laptop.
Old Apr 30, 2009 | 05:46 PM
bad venge's Avatar
bad venge
Section Moderator
3 1/8" bose tweeters are a direct drop in (under $20 a pair off ebay)
To adapt them I cut a plexi blank with a hole saw then cut the center out to mount the tweeter, then use the stock grill to cover them
Old May 7, 2009 | 08:09 PM
robertwyoung
Default Starfish
http://www.supermotors.net/registry/15191/69469
Sorry that took so long ... it slipped my mind.
