1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
SCREEECH! Possible A/C issue
Old May 21, 2009 | 12:41 PM
JVenger's Avatar
JVenger
Default SCREEECH! Possible A/C issue
hey, new to the forum. I wanted to see if anybody can help with my 2000 dodge avenger. it screeches when I have the A/C is on and gets worse when i accelerate but when I turn it off it goes away. replaced a/c belt and even steering pump. Could it be the alt. belt instead? can anybody help me? thanks
Old May 21, 2009 | 02:10 PM
candacebadie's Avatar
candacebadie
Sounds like the compressor, but here's a few ways you can trouble shoot. Try putting a little WD-40 on the pulleys (alternator, power steering, crankshaft, etc.) one by one if this doesn't help, try tightening your serpentine belt a little bit and see if this stops the squealing. If not then your compressor may have bad bearings in it. GOOD LUCK
Old May 22, 2009 | 02:19 AM
bad venge's Avatar
bad venge
Section Moderator
I can't say I'd recomend WD 40 ... it may damage the new belts you have installed ... maybe some belt dressing ... but spray on stuff is normally a bandaid ... I'd double check the belt tensions anymore then 1/4" deflection is too much
Old May 23, 2009 | 07:03 PM
JVenger's Avatar
JVenger
turns out to be a bad or loose serpentine belt. added belt dressing to it and the squeak went away but comes back. I'll change the belt instead when i get a chance. thanks!
