Help!! Tranny!!
Is there a way I can easily get to the torque converter to check the bolts? I have a knocking that I suspect is either rod knock, or torque converter bolt...which I had worked on last summer by a shop. Also, the converter whines, if I can get in there...is there any way to fix that?
(It's a 1998 2.5L V6)
Thanks!!
Thanks!!
That's where it gets tricky...I have to get the car warm first...most of the time, I don't hear it, but it's been on and off getting a little worse. If I do hear it, and I'm sitting in drive, if I put it in reverse...it goes away, or at least changes pitch.
I'm sorry, but which one is the inspection plate?
Thank you
Thank you
But, it's been the other way too...where if I hear it in reverse, it'll go away in drive. Sometimes its in every gear, even in park. I had the torque converter worked on last summer, which makes me think that they could rattle loose over a year. The knock will go away with a slight rev of the motor too.
