1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
V6 timing belt question.
Old Jul 8, 2009 | 02:21 PM
dava2500's Avatar
dava2500
Default V6 timing belt question.
In the manual, when refering to reinstalling the tensioner it states "Using special tool No. MD998767 and a torque wrench on the tensioner pulley, apply 39 inch lbs. (4.4 Nm) of torque to the tensioner. Tighten the tensioner pulley bolt to 35 ft. lbs. (48 Nm). "
Any body know what this tool looks like, where you can get one, and what is the purpose of this step ?
I thought the tensioner was hydraulic, so why do you need to put a 'torque' on the tensioner pulley before tightening the tensioner bolts ?
Thanks in advance
Old Jul 9, 2009 | 07:41 AM
dava2500's Avatar
dava2500
So nobody takes this step ?
I notice the tensioner pulley hole is offset, so when replacing the pulley, how do you know where to position it relative to the mounting cam ?
Any info would be greatly appreciated
Old Jul 9, 2009 | 09:23 PM
bad venge's Avatar
bad venge
Section Moderator
https://dodgeforum.com/forum/diy-do-...bad-venge.html
