1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
A turbo 97 Avenger
Old Oct 25, 2009 | 04:14 PM
Moparmatt440's Avatar
Moparmatt440
Default A turbo 97 Avenger
I just wondering if anyone has done it, if so where would I plumb in the oil feed for the turbo? Its a 2.0L DOHC, I know a return tube will need to be welded into the oil pan, just wondering for the feed, should I just plumb into the oil pressure sensor plug?
Thanks
Old Oct 25, 2009 | 08:25 PM
bad venge's Avatar
bad venge
Section Moderator
Many "T" off the sender others are using the pancake tap on the oil filter
Old Nov 8, 2009 | 07:00 PM
Moparmatt440
Cool thanks, another question, do you know of any links on how to install a turbo timer on these cars? The only one I can find is for the SRT-4, Thanks
Old Nov 10, 2009 | 04:51 PM
bad venge's Avatar
bad venge
Section Moderator
Look on the 2G Eclipse forums ... I know it's there
Old Nov 27, 2009 | 10:43 PM
Moparmatt440
Just wondering are the cams on these cars one hole should be up and the other down right? I have the int hole facing up and the exh down is this right? The hole Im talking about is the hole or pocket in one of the journals on the cam
Old Nov 27, 2009 | 11:47 PM
bad venge's Avatar
bad venge
Section Moderator
cylinder 1 needs to be TDC
Old Nov 28, 2009 | 11:05 AM
Moparmatt440
Yea I know that, Im just wondering about the cams, and the markings on the gears? DO you use the same marks that are on the opposite side for the 2.4L or do they use different timing marks?
Old Nov 28, 2009 | 07:08 PM
bad venge's Avatar
bad venge
Section Moderator
last one I did had aftermarket adjustable gears so not sure on stock pulleys
