1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Aftermarket ECM...or Reprogramming?
Old Nov 1, 2009 | 01:22 AM
Tiddy427's Avatar
Tiddy427
Question Aftermarket ECM...or Reprogramming?
Where can I get this done, or where can I buy one?
Old Nov 1, 2009 | 08:34 AM
bad venge's Avatar
bad venge
Section Moderator
Why or what do you need reprogrammed ???
Old Nov 1, 2009 | 10:10 AM
Ridge's Avatar
Ridge
The only thing you can do to your ecu is send it into jet chips they reprogram your chip for better preformance I think there is 3 stages depending on what you have on your car. Stage 1 is non modded cars, stage 2 is lightly modded cars(performance exhaust, cold air intakes, headers etc.) and stage 3 is for heavily modded cars(turbos/superchargers with all listed above). On any performance parts site you will probably find it under performance chips or ecu upgrade kit. It cost about 250-300$, and your ecu gone for a week.
Old Nov 1, 2009 | 06:58 PM
bad venge's Avatar
bad venge
Section Moderator
Jet is JUNK ... Mine went out three times and came back WORSE every time ...
As mentioned WHAT are you trying to change/Improve ???
Old Nov 2, 2009 | 01:18 AM
Tiddy427's Avatar
Tiddy427
I was just curious as to how much power I could get out of a stage 2 or 3 ECU reprogramming? I'm not looking into it for right away, just for future reference...I have a complete aftermarket exhaust and intake, but not much else really...at least for the moment
Old Nov 2, 2009 | 07:58 PM
bad venge's Avatar
bad venge
Section Moderator
Truthfully not much gains unless you have far more mods ...
Old Nov 28, 2009 | 11:16 AM
Moparmatt440's Avatar
Moparmatt440
Does Mopar still make that one ecu upgrade? I know they made one for the older neons wouldnt they work for these cars?
Old Nov 28, 2009 | 07:03 PM
bad venge's Avatar
bad venge
Section Moderator
Howell automotive lists two different ones so I doubt the neon will work
