1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
New to Manual
Old Nov 20, 2009 | 10:24 PM
crazyvenge's Avatar
crazyvenge
Default New to Manual
Ok guys i hope u guys can help wit this.. umm got a 95 avenger manual n im having trouble wit the backin up lights they dont turn on when i hit reverse, i checked all the fuses n they are good so dont knwo whats the problem. canu help?
Old Nov 20, 2009 | 10:32 PM
hydrashocker's Avatar
hydrashocker
Welcome,
Let me move this over the the correct section for you.
Old Nov 20, 2009 | 10:37 PM
Midnight Runner's Avatar
Midnight Runner
If you have a volt meter, take out the bulb and take a voltage reading where the bulb was Volt meter on DC. setting. You could have a short in a wire. Also welcome to D.Forum.
Old Nov 21, 2009 | 01:58 PM
bad venge's Avatar
bad venge
Section Moderator
Theres a back up switch that might not be activating
Old Nov 22, 2009 | 12:52 PM
crazyvenge's Avatar
crazyvenge
a back switch where could that be at
Old Nov 22, 2009 | 01:02 PM
crazyvenge's Avatar
crazyvenge
a back up switch where could that be at
Old Nov 22, 2009 | 03:01 PM
crazyvenge's Avatar
crazyvenge
Default BAck up lights
ok i check n no current passing through the back lights dont know why. any ideas why?
Old Nov 22, 2009 | 08:26 PM
Tiddy427's Avatar
Tiddy427
Thumbs up
I had the same prob in my 95, I changed the back up switch (on top of the trans, Straight under the air intake...on the 2.0L, anyways) and worked perfectly! Switch was only like $25...that's where I'd start
Old Nov 22, 2009 | 09:05 PM
bad venge's Avatar
bad venge
Section Moderator
octagon shaped with two wires on top of the tranny
