1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
A604 Transmission Solenoid...
Old Dec 21, 2009 | 05:28 PM
Mavman's Avatar
Mavman
Default A604 Transmission Solenoid...
Ok so I tries replacing the solenoid with another and it ended up having 3 nipples on it instead of 2. I have one ordered but the guy couldn't tell me if theirs has 2 or 3 nipples on it and just kept telling me that they are all the same. I had it second day shipped to me so it will be here Thursday. The question is, Do i have to do anything to the gasket or do i just put it on and torque it down???
Help is appreciated :P
Old Dec 30, 2009 | 04:30 PM
virginatheavenger's Avatar
virginatheavenger
new gasket is prefered and they are quite easy to rebuild
Old Dec 30, 2009 | 05:13 PM
92dak5.24x4's Avatar
92dak5.24x4
I've rarely seen a solenoid pack fail. there are 2 different designs and you have to be careful to use the correct corresponding gaskets. but WTF do you mean by 'nipples'? The 3 bolts are torqued to 105 in-lbs.
Old Dec 30, 2009 | 10:40 PM
master tech's Avatar
master tech
Site Moderator & Tech
mavman
All new solenoid packs are the same. They all have 3 nipples has you call it. But once you torque the solenoid pack down , one of them gets pushed into the pack and you don't see it. There was two designs, old design had a plate and two gaskets. New design only has one gasket.
