1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Hi Everyone
Old 02-17-2011, 10:33 PM
Maingregory's Avatar
Maingregory
Maingregory is offline
Hey bad venge, at the risk of annoying you....a few more questions. I know its been a while since i have been on the forums. If you do the engine swap over to the 3.0l 6g72 do you use the crank position sensor in the transmission? or is it not located on the engine block.
If it is located in/on the engine block what would keep me from swapping out the 6g73 and auto transmission for a 6g72 and a A543 manual transmission. (besides money) I would greatly appreciate your response on this.
My headliner for the sunroof cover is drooping....i have tried fixing it one to no avail. any ideas that would help?
Old 02-18-2011, 07:38 PM
bad venge's Avatar
bad venge
bad venge is offline
Section Moderator
Dodge Forum Moderator
CPS in Tranny ...
Manual will not fit the chassis there has been several try and never got it to work
Old 02-18-2011, 07:40 PM
Maingregory
ok, well if anything i might do what silvercoupe did. also what would i need to convert to the eclipse center console?
Old 02-18-2011, 09:27 PM
bad venge's Avatar
bad venge
Section Moderator
center console /sides/auto plate/hvac surround/ radio mounts
