1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
98 Avenger Keyless Entry
Old Mar 20, 2010 | 05:45 PM
lvdgrl85@aol.com's Avatar
lvdgrl85@aol.com
Default 98 Avenger Keyless Entry
Does anyone have a guide on how to install an aftermarket keyless entry unit? No alarms or remote starts, just a keyless entry. Thanks in advance!
Old Mar 20, 2010 | 06:31 PM
bad venge's Avatar
bad venge
Section Moderator
1998 Dodge Avenger Alarm, Remote Starter, Keyless Entry Wiring Information
Constant 12V+ White Ignition Switch Harness
Starter Black/Red Ignition Switch Harness
Ignition Black/White Ignition Switch Harness
Ignition 2 Blue Ignition Switch Harness
Accessory Blue/Black Ignition Switch Harness
Tach Brown Coil Pack
Neutral Safety Wire Black/Yellow (-) Switch Driver's Side of Transmission
Brake Switch Green Brake Switch
Trunk Pin Red/Green (-) Trunk Light
Parking Lights Green/White 18 Pin Connector at Fuse Panel
Head Lamp Red Light Switch or Steering Column Harness
Factory Disarm Light Green/Orange Driver's Door Boot or Green/White Driver's Kick Panel
Door Trigger Red/Green (-) Driver's Kick or Black 19 Pin Connector on Back of Fuse
Door Lock Brown/White (-) Driver's Kick Panel or Relay below Radio
Door Unlock Brown (-)
Horn Wire Green/Black (-) Steering Column White 3 Pin Connector
Windows Up LF=Green/Red, RF=Brown/Yellow MAIN
Windows Down LF=Green/Black, RF=Green/Yellow
Is the full wiring diagram for wires/location you have to sort thru what you need it depends on the remote unit you have
