1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
windows don't work
Old Apr 3, 2010 | 12:40 PM
JLA74's Avatar
JLA74
Default windows don't work
For some reason both the power windows stopped working. I have the panels apart, does anyone know which wires are supposed to have power for the windows?
98 avenger sport.
Old Apr 3, 2010 | 01:36 PM
JLA74's Avatar
JLA74
yes I checked the fuse.
Old Apr 3, 2010 | 05:07 PM
bad venge's Avatar
bad venge
Section Moderator
Did you check the 30a under the hood ?
for wiring diagram:
http://www.sailor.lib.md.us/cgi-bin/ebsco?DB=auto
enter this :
21947001622114 for card #
Then you can enter make model
Old Apr 5, 2010 | 12:06 PM
JLA74's Avatar
JLA74
Isn't the 30A under the hood the only one? That is the one I checked anyway and actually switched it out with another which I know is good. Thats the first thing that came to mind when both windows quit working at the same time.
Old Apr 5, 2010 | 12:30 PM
JLA74's Avatar
JLA74
Thanks for the wiring schematic. So it could be the fuseable link or the relay. Where is the relay located?
Old Apr 5, 2010 | 08:36 PM
JLA74's Avatar
JLA74
So I tested everything out tonight and found out there isn't any power getting to the door. For some reason the relay isn't switching. I tested it and it switches when I bench test it but not when it is installed. There is power getting to it. That only leaves something on the other end like a ground. The blue/yellow wire must control the switching. What could be the issue with that end? It goes to the anti-theft / where ever that goes. Any suggestions??? I am pretty much stumped from this point. I tested both windows and they all work fine.
Old Apr 5, 2010 | 09:18 PM
bad venge's Avatar
bad venge
Section Moderator
I'd try grounding the other side of the coil and see if it then works, then you'll have to trace that wire out
Old Apr 6, 2010 | 09:05 AM
JLA74's Avatar
JLA74
Thanks venge,
The wire goes to the ECU input for anti/theft. I know it will work if I jumper the relay, I just don't understand the anti theft part of the equation and if I can do anything with this.
Old Apr 6, 2010 | 09:10 AM
JLA74's Avatar
JLA74
Here is the diagram
File Type: pdf
Old Apr 6, 2010 | 08:49 PM
bad venge's Avatar
bad venge
Section Moderator
if you read there are two options one with antitheft , one without antitheft pin 33/or 35
you'll have to check the connectors and see where its hooked up , I'm noticing some differences in the trunk switch circuit with and without I'd check there as well
