1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Cruise control Question
Old Apr 9, 2010 | 12:37 AM
Avenger1996's Avatar
Avenger1996
Question Cruise control Question
okay guys im sure someone here knows what im missing and maybe even has the part i need for sale but im kind of stumped on this my avenger is the 1996 avenger 2.0 dohc 5spd, i had the engine replaced last summer when i thre a rod out of the other one i put in another 2.0 dohc engine out of a 1995 avenger shortly after that i developed cruise control issues the cruise switch in the dash the little orange light does come on but thats it i have replaced the cruise servo checked the Vac lines replaced the switch in the dash and the switch in the steering wheel as well as the relay granted i got all these part off my parts venge that cruise was working on when the car gave up what am i missing i still have no cruise?
Old May 2, 2010 | 04:46 PM
mfahey's Avatar
mfahey
I'm at the same place as you with our Caravan. Light comes on even when you don't press the on button. I replaced the clockspring since that's a known issue with Caravans and the cruise buttons all go through it. When that didn't work, I replaced the servo.
When that didn't work, I thought I had it narrowed down to the ECU since everything goes through there but that didn't do anything. I then replaced the on-off-set button and that also didn't work. I've tried checking voltages at the brake light switch and at the connection on the servo that vents the vacuum. I also disconnected the resume/cancel button on the theory that it was permanently canceling the cruise command but no go.
I'm assuming that the vehicle speed sensor is ok since the transmission shifts well and the speedometer works.
I just can't imagine what else it could be unless there's some input that the ECU doesn't like.
Old May 13, 2010 | 04:10 PM
V8MANual's Avatar
V8MANual
How do I get the cruise switch out? My 'resume' button is stuck (since yesterday) and the cruise won't function.
I've removed the airbag module and the single screw in the rear of the switch assembly, but something is still holding it to the wheel. I don't want to force it and break something else!
This is on my '05 Town & Country.
Old May 14, 2010 | 08:28 AM
mfahey's Avatar
mfahey
I'm assuming your 2005 is the same as my 2001 but there were 2 screws from what I remember. You might have to tuck your head back in there to see if there is a screw you are missing.
Old May 14, 2010 | 09:56 PM
V8MANual's Avatar
V8MANual
Thanks, there were two tiny screws; I had to use a knife blade to remove them. The metal switch plate was bad, so I tossed it. I moved the plate from the 'coast' button to the 'accel/resume' button. I NEVER 'coast' LOL.
Old May 31, 2010 | 10:11 PM
mfahey's Avatar
mfahey
My cruise is now working. All I did was do a routine transmission service and lo and behold, everything works.
All I can figure is that when the cruise light was always lit on the dash, it was actually indicating a problem. I have no clue as to why changing the fluid would cause the problem to go away but there you go.
