1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
98 dodge avenger wont start
Old May 8, 2010 | 08:57 AM
5996laud's Avatar
5996laud
More info. When the car trys to start. The fuel pump comes on for the second time. So its getting a signal from the computer.
Old May 8, 2010 | 01:05 PM
5996laud's Avatar
5996laud
I checked the ASD relay. 12V power constant , Turn on key 12V power, 12v power feed and the ground. I think its good. Went to autozone and used there autoscanner. There is 0 codes. I guess the computer is working.
Old May 8, 2010 | 01:31 PM
5996laud's Avatar
5996laud
I just put the timing light on it. Its fireing 25 degrees before TTC. I think thats the problem. And the sputter. What should I check or test ?
Old May 8, 2010 | 01:54 PM
bad venge's Avatar
bad venge
Section Moderator
sputtering is likely the timing as well
Old May 8, 2010 | 08:30 PM
5996laud's Avatar
5996laud
So what shoud I check ? Or what controls the timing ? I just removed the power steering pump and the belt covers. The belt is good and the 3 timing marks line up. And I have tested the crankshaft sensor. Any suggestions.
Old May 8, 2010 | 09:44 PM
bad venge's Avatar
bad venge
Section Moderator
Timing can be adjusted by the computer preset from the factory there was an Icon unit by superchips that allowed further adjustments
Old May 10, 2010 | 09:17 PM
5996laud's Avatar
5996laud
Went to the junck yard sunday and pickup a distributor for 30. Installed and it started right up. The old distributor wasn't turning freely and was some how caused the timing to be 25 before TDC. I'm on the road . Thanks for all the help
Old May 12, 2010 | 08:21 PM
5996laud's Avatar
5996laud
Had a stalling problem, But I just had the vacuum lines on the map sensor wrong.
Old Aug 7, 2011 | 02:16 PM
gizmomartin's Avatar
gizmomartin
Angry no spark again....
I have a 98 Dodge Avenger 2.5 V6. having the same problems that I have read on here with other owners. ( NO SPARK ) from the distibutor ! had this problem a yr ago and found it to be the cam sensor, of which is built into the distributor, so replaced the whole high dollar distributor. problem solved. but now a yr and a half later the same condition happens ! car wont start and no spark coming from distributor. I was reading bout the ASD and Fuel relays, and the car has the problem that was said bout these relays- meaning stalling out while driving. going to chk on these relays to see if working properly. but any help would be greatly appreciated, thanx
Old Aug 21, 2011 | 01:06 PM
gizmomartin
Default no spark again....
I tested all 3 relays and they were working fine, tested crank sensor and was working fine. so replaced the distributor once again and away it went, wth !! this makes 2 distributors in less than 2 yrs. now that my car has gone thro. why it keeps eating up the distributors is beyond me !
