1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Alternator is bad, and a whining noise
Old 06-20-2010 | 08:33 PM
v6avenger09's Avatar
v6avenger09
Default Alternator is bad, and a whining noise
I know my alt is bad, the batt light is on and when i unplug the + terminal, the car dies. but i also have a really bad whining noise from near the alternator on the pass side but idk if it is the alt or something in the motor. anybody else ever have this problem?
Old 06-20-2010 | 10:12 PM
bad venge's Avatar
bad venge
Section Moderator
bad bearings in the alternator
Old 06-20-2010 | 10:22 PM
v6avenger09
So would I need to replace just the bearings? Or the whole alt? It was smoking...
Old 06-20-2010 | 10:56 PM
bad venge's Avatar
bad venge
Section Moderator
Likely the entire alternator
Old 06-21-2010 | 06:56 PM
v6avenger09
alright, i got everything out of the way and all of the alt bolts off. i just have one quick question, how do you remove the alternator electrical cable and the "b+" cable? the repair manual isnt very specific. do i just pull them out or twist? and then, how do i pull the alt out? through the top or out the bottom? thanks again badvenge, i REALLY appreciate all of the help you have given me with everything
Old 06-21-2010 | 09:44 PM
bad venge's Avatar
bad venge
Section Moderator
I removed mine 12 years ago to put in my 185 alternator so I forget cable removal.
I've pulled them out both ways, I prefer out the top as the manifold takes me 15 minutes
