1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
How to replace EGR-valve?
Old 07-17-2010, 07:20 PM
sapporo's Avatar
sapporo
sapporo is offline
there sure can be more than 1 sensor infact you'll have a minimum of 2, so you need to look at and see if you can find them all.
Old 07-18-2010, 12:01 AM
bad venge's Avatar
bad venge
bad venge is offline
Section Moderator
Dodge Forum Moderator
21 Upstream HO2S stays at center Harness and connector / Upstream HO2S
21 Upstream HO2S shorted to voltage Harness and connector / Upstream HO2S
21 Upstream HO2S response (M/T) Harness and connector / Upstream HO2S
21 Upstream HO2S heater failure (M/T) Harness and connector / Upstream HO2S
21 Downstream HO2S stays at center (M/T) Harness and connector / Downstream HO2S / Fuel system
21 Downstream HO2S heater failure (M/T) Harness and connector / Downstream HO2S
21 Downstream HO2S shorted to voltage (M/T) Harness and connector / Downstream HO2S
Old 07-18-2010, 04:09 AM
jonthee's Avatar
jonthee
jonthee is offline
Thank you!
Hmm, when I looked at the parts list (the pdf-document) I saw that it could be 4 of them, one after the extract, one after the manifold and two around the catalytic converter.
Gonna try to change the one after the extractor.. =)
Best regards
Old 07-18-2010, 08:46 PM
bad venge's Avatar
bad venge
Section Moderator
Check for VOLTAGE first!!! if there is no voltage none will work and you can swap forever and never fix it
Old 07-19-2010, 01:45 AM
jonthee's Avatar
jonthee
jonthee is offline
How will I check for voltage?
There are 4 wires to each of the sensors =/
Old 07-19-2010, 12:12 PM
sapporo's Avatar
sapporo
sapporo is offline
i use a scanner. it shows me the voltage the computer is seeing.
Old 07-19-2010, 01:18 PM
jonthee's Avatar
jonthee
jonthee is offline
hi again!
I only have a voltage-meter.
How will I measure the voltage, loosen the connectors one by one and connect to which wires? There are 4 wires to each of the sensors.
Old 07-19-2010, 03:07 PM
sapporo's Avatar
sapporo
sapporo is offline
IDK, that's what service manuals have infomation on. it also depends on which side you measure with it unplugged.
there's a 12v wire, a couple ground wires and a signal wire
Quick Reply: How to replace EGR-valve?
