Replacing Shocks on 99 avenger
I have managed to tear apart the entire rear end of the car and have come to a freezing point. The rear shock mounts seem to be covered by the interior.
I would like to know what the best way to remove the rear interior without destroying it. Also If anybody can direct me to a good thread that has pictures or even an explanation about replacing a shock mount would be much appreciated. I have tried searching the forum and google which resulted in nothing and then reviewed page by page until I went slightly insane in the forum.
Thank you.
Thank you.
Drop rear seat backs down remove the two plastic pieces that form an arch across the rear behind the seats , mounts are behind there... I believe 2 14mm bolts to drop the mounts and remove the bottom bolts to remove the strut assembly , use a spring compressor to compress the spring remove the top bolt and top hat assembly examine te rubber bushing and te rubber isolator replace strut /reassemble
http://www.2gnt.com/index.php?d=Strut%20Install
What is the best way to remove the two sides that make up the back seat. I can stick my hand behind them but cannot find anyway to release them. So I do not have to take off the carpeting that is on the top with the speakers correct?
Thank you very much for the help.
I figured it out. Thank you. There was one bolt that I overlooked and after that everything came out flawlessly.
