1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
96 avenger miss
Old Jul 31, 2011 | 12:36 PM
tsmith2000's Avatar
tsmith2000
Question 96 avenger miss
i bought this 96,avenger in feb it ran great than got stuck in second gear so i took it to the trans shop to get repaired. i got it back bout three weeks ago and it has a bad miss ever since it isnt giving a check engine light or nothin. its a 2.5 v-6 i have replaced the air,fuel filters plugs,wires,intake gasket,distributor cap and the rotor buttoni misses in park when you rev the engine and thruout driving ranges tryed water remover in the fuel and injector cleaner also any help would be greatly appreciated?
Old Jul 31, 2011 | 06:53 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Welcome to the site. I moved this thread to the Avenger section,
FF
Old Jul 31, 2011 | 10:14 PM
bad venge's Avatar
bad venge
Section Moderator
I'd guess a bad distributor or bad injector since you replaced about everything else
Old Feb 5, 2012 | 10:03 AM
tsmith2000's Avatar
tsmith2000
ok replaced the injectors the distributor and soon my hair and still no engine light or anything please help me
Old Feb 5, 2012 | 02:57 PM
bad venge's Avatar
bad venge
Section Moderator
You replaced all 6 injectors and the distributor ? and it's still missing
is there a check engine light ?
Old Feb 6, 2012 | 09:02 AM
tsmith2000's Avatar
tsmith2000
i replaced two of them and checked that the rest was working and replaced the distributor and still misses and checked that the check engine light is working properly and it works fine did key dance and still nothing ? had this thing for a year and really have more in it now than its worth so for me its fix it and drive it for a while even if it mean new motor have to get some use out of it
Old Feb 6, 2012 | 03:59 PM
bad venge's Avatar
bad venge
Section Moderator
Just replacing 2 and checking the others can not prove that it's not the injectors it could be the electrical feed/connectors as well ...
There could be a bad connection/to the distributor , bad defective cap/rotor/wires/plugs
there could be oil in the plug wells grounding the spark ect ect
have you tried to get the codes scanned ? possibly there is a code and the CEL is bad/defective
Just cause you "replaced" a part doesn't mean that it was done properly or the part can't be bad defective out of the box ... did you use a new or rebuilt distributor?
Old Feb 7, 2012 | 11:52 AM
tsmith2000's Avatar
tsmith2000
bought distributor from salvage yard out of a car that i heard run so i know it not that hopefully and tryn right now to locate cheap new injectors
Old Feb 7, 2012 | 12:15 PM
tsmith2000's Avatar
tsmith2000
ichecked the connectors to the injectors to make sure they all were getn good conection when i changed the plugs and wires and they seem to be fine im fixing to take the car to the dealer to have it put on their expensive computer to see if that will tell me anything in the next week or so
