1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
1997 Dodge P1494 and tachometer upto 2000 when starting
Old Aug 2, 2011 | 04:59 AM
DodgeAvg's Avatar
DodgeAvg
Default 1997 Dodge P1494 and tachometer upto 2000 when starting
I have 1997 Dodge Avenger.
Recently the "check engine" showed up, i went to service, they got me the P1494 and switched off that light.
They told me that, if it comes back again, then bring car again to us and we will look, is it LDP switch or mechanical fault.
Now after few weeks the light turned on again.
But i also noticed that when i start the cold engine, then the tachometer shows almost 2000 RPMs and then goes down. Of course i hear how engine goes up and down when starting.
I don't know if it does same with warm engine.
Is this normal or not? It's got something to do with LDP?
I also have read in some forums that even bad (old) fuel hoses under the car could light up this little lamp.
So in general: should i be very worried about that all?
Thanks for any help and information.
Old Aug 2, 2011 | 04:48 PM
bad venge's Avatar
bad venge
Section Moderator
Definition :
Evap Leak Detection pump pressure switch condition
Explination:
ECM detected the leak detection pump switch did not change after the solenoid was energized
Probably Causes:
1. Leak detection pump defective
2. open or shorted circuit condion
3. solenoid defective
Old Aug 3, 2011 | 05:42 AM
DodgeAvg's Avatar
DodgeAvg
Can this be reason for increased fuel consumption?
I think my car drinks the fuel too much.
Old Aug 3, 2011 | 05:02 PM
bad venge's Avatar
bad venge
Section Moderator
doubtful it's normally a bad O2 sensor that causes that
Old Aug 4, 2011 | 04:14 PM
DodgeAvg's Avatar
DodgeAvg
Where is it located?
I said, that i don't have any ebook about Dodge..
Only that crappy AllData.
I have an car mechanic that could replace all bad parts but i need to know what and how they look like, where are they located etc.
I will give him the parts and he will do the job. He knows my car anyway already. It's my ex GF car. Her boyfriend works at car repair.
What about the 2000 RPM when starting engine?
Is it normal? It goes up to 2000 when starting engine and then goes down to normal.
I didn't notice when it started, if i remember correctly it was always like that, but im not sure.
So any help with that is also very welcome.
Old Aug 4, 2011 | 04:55 PM
bad venge's Avatar
bad venge
Section Moderator
You don't state what motor as there are 2 available theO2 sensors are in the exhaust manifolds the v6 has 4 , 2 before the cat and 2 after cat
Mine goes to 1800 and then idles back to 1000 when it gets warm
Old Aug 5, 2011 | 04:30 PM
DodgeAvg's Avatar
DodgeAvg
6V?
Maybe you meant 16V?
2.0 16V DOCH, 104kW.
Little OT:
It's this:
http://eng.auto24.ee/used/552918?id=...ache_missing=1
Same car i own atm.
Of course it looks alot better now, i cleaned up the lights, thanks to the tutorial i found here in the forum and many other things are made better.
/OT
Old Aug 26, 2011 | 05:19 AM
DodgeAvg's Avatar
DodgeAvg
The Check Engine just switched off.
I didn't notice when.
What it means?
Let's assume the lamp didn't die. But it just switched off?
Can this be possible?
Old Aug 26, 2011 | 11:27 PM
bad venge's Avatar
bad venge
Section Moderator
sometimes they reset other times in minor issues it will turn off then come back on X# of key cycles later
Old Feb 20, 2012 | 04:47 AM
DodgeAvg's Avatar
DodgeAvg
The da*n cold winter is screwing my car.
Another problem.
When i start my car, it's ok, but then the rpm goes below 1000 and it feels like whole car is shaking.
Then it goes back to 900-1000 something. Dunno what the hell it is.
It started when i drove over snow and got stuck, i couldn't get away anymore. I had to dig out my engine to get away. The whole engine at lower part was in a pretty hard snow, almost like ice. Including the front wheels
Maybe i break some cables or sensor there, dunno.
Any ideas what should i check?
Sorry for my bad english.
