1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Front Strut Replacement Help
Old Aug 13, 2011 | 09:34 AM
reed2222's Avatar
reed2222
Default Front Strut Replacement Help
Could someone send me an old thread link on how to replace my front struts. Ive search but no luck.
Thanks in advance.
Old Aug 13, 2011 | 06:07 PM
bad venge's Avatar
bad venge
Section Moderator
http://www.2gnt.com/index.php?d=Strut%20Install
Old Aug 14, 2011 | 07:38 AM
reed2222's Avatar
reed2222
Thank you so very much "BV"
Old Aug 14, 2011 | 07:13 PM
reed2222's Avatar
reed2222
Ok.... Not taking anything away from you "BV" you have help me many times, but im not sure of wrote that thread but its not Avenger related. The first page clearly states that a spring compression tool is not needed. Well im here to say that it is. The first one about took my son head off... the second went well .. went to Auto Zone and rented a spring compression tool.
Old Aug 14, 2011 | 10:06 PM
bad venge's Avatar
bad venge
Section Moderator
that is a mitsubishi thread and I've pulled them off without spring compressors all the time.
I stand on the spring and let the top release
