1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Car pc install
Old Jan 15, 2012 | 01:26 AM
Ghoulface's Avatar
Ghoulface
Question Car pc install
I am gathering parts to install a car pc into the dash of a 2000 dodge avenger and i would like to know how much room there is in the dash?? i might go as far as installing it by the firewall if needed
thank you!
Old Jan 15, 2012 | 02:03 AM
bad venge's Avatar
bad venge
Section Moderator
IF you swap to an eclipse console 95/99 it gives you a double din opening and more room
and a larger screen size. I mounted the carputer under the seat feeding a touch screen
Old Jan 15, 2012 | 02:08 AM
Ghoulface's Avatar
Ghoulface
how much would a eclipse console cost? the car pc case i want to mount is twice the height of a regular car pc thats why i would like to find room behind the dash.
Old Jan 15, 2012 | 02:21 AM
bad venge's Avatar
bad venge
Section Moderator
theres not much room behind the dash I fit a PS2 behind the glovebox its tight thats why I went underseat
the eclipse console can be $50/$80 junkyard price
Old Jan 15, 2012 | 02:32 AM
Ghoulface's Avatar
Ghoulface
sweet now just to find a junkyard with an eclipse
Old Jan 15, 2012 | 02:42 AM
bad venge's Avatar
bad venge
Section Moderator
http://yourwhip.com/189-badvenge/pho...7#photoid=1130
Old Jan 15, 2012 | 02:58 AM
Ghoulface's Avatar
Ghoulface
i studied your photo and ran outside to my car just to see the difference and the eclipse center console will fix all my problems. btw i have a single din aftermarket radio that has a screen that extends out and flips up, with this eclipse console i can now use the screen because the shifter will not get in the way! sweet i am now on a mission to find one!
Old Jan 15, 2012 | 09:35 AM
bad venge's Avatar
bad venge
Section Moderator
http://www.ebay.com/itm/95-99-Eclips...item3f12546efd
http://www.ebay.com/itm/95-99-Eclips...item3370571eaf
http://www.ebay.com/itm/95-99-Eclips...item337057203c
You will need side panels and the eclipse HVAC and the eclipse radio cage and the shfter plate as well
Old Jan 15, 2012 | 02:10 PM
Ghoulface's Avatar
Ghoulface
Alright now i have ordered black center console and carbon fiber side panels for it.
now all i need it hvac, radio cage and shifter plate.
im currently looking for the shifter plate but all im finding is the whole A/t Shifter.
