1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
This mom needs HELP!!!
Old Jan 31, 2012 | 12:20 PM
pradmore29's Avatar
pradmore29
Red face This mom needs HELP!!!
I have a 2000 Dodge Avenger and she has a grinding noise coming from the driver side tire..it start's at 5 mph and is loud..the breaks have been changed about 3 months ago...Please any help is better then none...
Old Jan 31, 2012 | 03:52 PM
bad venge's Avatar
bad venge
Section Moderator
Sounds like a bad wheel bearing or CV joint
Jack up the car and see if the wheel wobbles/has movement That would indicate the wheel bearings gone
Old Feb 3, 2012 | 05:08 PM
DodgeAvg's Avatar
DodgeAvg
Sorry for using your topic but i have similar issue (actually had a long time already) but it's just a bit annoying.
There is some "whining", don't know if it's even correct word for it. It starts with low speed and when i drive over 50km/per hour it disappears.
If i slow down to 50 and below it comes back. I don't know the lowest level, where it starts but i know for sure it disappears when going over 50km per hour. The range for me seems to be 40-50 km per hour. Somewhere in there i think the sound is heard mostly.
Sound is like coming from everywhere, i don't have exact point where it comes. Just sounds like from everywhere.
Why it disappears at specific speed?
Wheel bearing(s) or something even worse?
Old Feb 3, 2012 | 07:01 PM
bad venge's Avatar
bad venge
Section Moderator
I'd say check wheel balance/wheel alignment first if the wheels are misbalanced this can cause issues at speed as well as worn/cupped wheels cause the noise
