1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Transmission help
Old Apr 10, 2012 | 09:48 PM
Avenger7688's Avatar
Avenger7688
Default Transmission help
What years and models can I get an auto trans from to put in my 97 avenger 2.5? Trans is dead so trying to see what donor cars I can look at.
Thanks
Old Apr 11, 2012 | 12:35 AM
master tech's Avatar
master tech
Site Moderator & Tech
1996 and 1997.
Old Apr 11, 2012 | 04:32 PM
bad venge's Avatar
bad venge
Section Moderator
97/00 venge/sebring coupe Stratus and Cirrus use the A 604 as well
I believe the 95/96 are different sensors/harness/ TCM
Old Apr 14, 2012 | 08:09 AM
Avenger7688
Bad venge.... U seem to be the resident expert on these forums about all things avenger. I can't find a 97 anywhere. 96 or 99 are my options . What do you think is the best bet and thanks again for all the help
Old Apr 14, 2012 | 08:27 AM
bad venge's Avatar
bad venge
Section Moderator
99 is the best of those 2 ... you can compare the sensors/plugs on the 96 as some (late production) used the same tranny
Old Apr 14, 2012 | 08:30 AM
Avenger7688
What will need to be modified on the 99?
Old Apr 14, 2012 | 06:08 PM
bad venge's Avatar
bad venge
Section Moderator
possibly nothing , at most input/output speed sensors and plugs
Old Apr 14, 2012 | 08:52 PM
Avenger7688
Ok thank you again for all the help
Old Apr 20, 2012 | 06:13 PM
Avenger7688
thank you to bad venge. 99 trans worked great with no modifications.
Old Apr 20, 2012 | 06:48 PM
bad venge's Avatar
bad venge
Section Moderator
I was pretty sure that was the case glad you are back on the road
