1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
98 dodge avenger 6cyl
Old Jun 2, 2012 | 09:49 AM
paulpgh's Avatar
paulpgh
Default 98 dodge avenger 6cyl
I am running a 98 avenger, When it sits in the driveway and idles the car runs fine, When I take it out on the road for a test drive after about 10 min it stalls out and wont start right up, if I let it sit 30 to 40 min it runs again for 5 miles and stalls again. Fuel filter? pump? IAC? any help would be great. I did close of the leak detection pump to see if I could get the CEL off is this a problem? Thanks in advance.
Old Jun 2, 2012 | 01:03 PM
bad venge's Avatar
bad venge
Section Moderator
The trouble can be a Fuel Pump Relay , ASD relay , or the CPS
Old Jun 3, 2012 | 07:52 AM
paulpgh's Avatar
paulpgh
If it was the asd relay shouldn't I have gotten a code 42? It's not the fuel pump relay. I will check the CPS. I'm wondering if I have a bad battery connection on the Neg terminal. This was just replaced and may have loosened while driving?
Old Jun 3, 2012 | 01:23 PM
bad venge's Avatar
bad venge
Section Moderator
intermottant they might not throw a code , doubt its a battery terminal or it wouldn't restart after waiting
Old Aug 4, 2012 | 10:39 AM
paulpgh's Avatar
paulpgh
Okay I have replaced the coolant temp sensor, fuel pump relay and the IAC and the car still stalls after 14 miles.I have the distributor out but don't know if I need the 526 or the 475 rotor cam?
Old Oct 31, 2012 | 05:24 PM
jpk123's Avatar
jpk123
crank position sensor...mine did same thing and it was the sensor
Posted from Dodgeforum.com App for Android
