1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
steering issue
Old Jun 7, 2012 | 12:18 PM
96avenger719's Avatar
96avenger719
Default steering issue
Hey guys
Im having a little trouble with my power steering. I took my avenger out for a quick drive and when i came back the steering went out (hard to turn the wheel) i popped my hood and saw the belt was loose, got that back on but the steering is the same as before. I checked my power steering fluid, still clean and full. So im kind of lost as to what to do next.
Is there a way to test the pump itself or????
Still new to the avenger mechanical wise anyways
Somebody help.
Old Jun 7, 2012 | 03:45 PM
bad venge's Avatar
bad venge
Section Moderator
Does it TURN , Look at the pump and watch with the motor running the Power Steering pump might be frozen/locked up and thats what derailed the belt
Old Jun 7, 2012 | 11:40 PM
96avenger719
The wheel barely turns, i mean i definitely cant make a full circle. Ill check out the pump tomorrow. What exactly am i looking for? How will i know if its frozen?
Old Jun 8, 2012 | 04:31 PM
bad venge's Avatar
bad venge
Section Moderator
Should be turning fairly easy by hand
Old Jun 11, 2012 | 11:39 AM
96avenger719
Checked it out yesterday, cant seem to get the belt to stay on whether i tighten the tensioner or loosen it up enough to turn by hand.
Old Jun 11, 2012 | 03:57 PM
bad venge's Avatar
bad venge
Section Moderator
Sounds like the pump still
