1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Misfire # 6 1997 ES
Old Dec 13, 2013 | 01:08 AM
newfuel2008's Avatar
newfuel2008
Question Misfire # 6 1997 ES
I am getting a cel code. Code reader says misfire detected on number 6 cylinder. I replaced all spark plugs. What else would cause a code like this?
The cel came on 2 weeks after the plug change. 91,000 miles..I am the original owner since new.
Any advice greatly appreciated.
George
Old Dec 13, 2013 | 01:33 AM
simmonsfr's Avatar
simmonsfr
What brand plugs did you buy? I don't buy champion plugs anymore because I had 1 bad plug in 2 separate multi-packs. It sounds like you have a bad plug. Also disturbing the plug wires can cause them to start grounding to the engine. Could also be distributor cap is corroded on the #6 conductor.
Old Dec 13, 2013 | 02:35 AM
newfuel2008
Denso Iridium plugs. I was very careful with the plug wires. Of course that doesn't mean much. I will replace the dist. cap and rotor next. Remember, I did not get a CEL until 2 weeks after the plug change.
Is there a means to pinpoint the exact cause without randomly replacing parts??
Thanks for replying.
Old Dec 13, 2013 | 08:49 AM
MoparMan1991's Avatar
MoparMan1991
DO you have a bad fuel injector? I don't know much about your vehicle, but if you have a clogged up injector then obviously you would receive a misfire CEL.
Old Dec 13, 2013 | 12:27 PM
bad venge's Avatar
bad venge
Section Moderator
Was there any sign of oil in the plug wells?
Bad wire /plug/rotor/cap/ distro/ or bad injector
If you suspect injector swap and see if code moves
Old Dec 13, 2013 | 12:52 PM
MoparMan1991
injectors are probably cheaper than plug wires. They're real easy to change too, although not as easy as changing a plug wire.
Old Dec 14, 2013 | 12:11 AM
newfuel2008
Thanks for responding. No dead miss. Seems to miss a little at cold startup. Clears right up. Runs great under load, and warm idle. No oil in plug wells. Old plugs were clean but well worn.
Would injector cleaner help added to fuel?/ That is, if it's an injector.
I appreciate the help....
Old Dec 14, 2013 | 01:17 AM
justinc89's Avatar
justinc89
My 98 dodge is doing the same thing. My misfire is showing up on cyc number 8 ii mess with wires a bit. Then the check engine light will stays off after i clear the code
