1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
1997 avenger v reg
Old Mar 23, 2016 | 12:31 PM
lbodenr's Avatar
lbodenr
Default 1997 avenger v reg
Need a source for a V Reg for 1997 Avenger 2.5L that can be mounted external to the Alternator. The regulator in my PCM is bad so I need an independent VR.
Old Mar 23, 2016 | 05:45 PM
Either replace the PCM, or, you are going to have to custom wire one. Of course, if you don't keep the PCM in the loop, it's going to whine about it.
Welcome to DF!
Old Mar 23, 2016 | 10:38 PM
lbodenr's Avatar
lbodenr
So if I:
1. Leave the 12v supply voltage line (supply voltage sense) to the PCM in place.
2. Splice in a new wire from the above supply line to the new V-Reg + input.
3. Cut the field control line (alternator field return) to the PCM.
4. Splice in a new wire from the alternator field return to the new V-Reg field control input.
5. Ground the V-Reg.
Does the above seem correct? The PCM would still be sensing the supply voltage and might then be happy?
I am looking for a V-Reg that is compatible with the 1997 Avenger 2.5L. The alternator does not have an internal regulator, and if the regulator in the PCM goes bad, adding an independent V-Reg may be easier/cheaper than replacing the PCM.
Old Mar 24, 2016 | 07:27 AM
Moved to the correct section.
Old Jun 3, 2016 | 07:30 AM
bad venge's Avatar
bad venge
Section Moderator
I bought a Plug and Play 180 amp Alternator that has an external Voltage regulator but wires into the pcm
