1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
1997 Avenger part help needed
Old May 2, 2022 | 08:05 PM
Hero6's Avatar
Hero6
Default 1997 Avenger part help needed
My parents have a 1997 Avenger base model (only 65,000 miles on it).I am trying to find them a bezel for the drivers side window switches. The part where the switches attaches to broke all 4 screw mounts. Can this be replaced separately or does the whole door panel have to be replaced? Where can I find parts for this thing, no luck with google, Amazon, or eBay. Any help would be appreciated
interior is gray
Old May 3, 2022 | 12:01 AM
master tech's Avatar
master tech
Site Moderator & Tech
You may need to replace the panel. I would remove first and see what you need. Have you Tried Rock auto. That is where I get most of my parts for my 96 avenger.
Old May 3, 2022 | 08:35 AM
Hero6's Avatar
Hero6
Rock Auto does not sell the part I need, haven't been able to find one anywhere. I checked the local junk yards, and no one has any avengers. I am not even sure if this trim piece can be separated from the door panel, looks like it may have some plastic welds in some spots holding it on.
Old May 5, 2022 | 11:35 PM
master tech
Have you tried the Mitsubishi dealer. It the same body as the Eclipse.
Old May 16, 2022 | 10:16 AM
Hero6's Avatar
Hero6
Wasn't having much luck finding parts, so I used some epoxy, hot glue, and 2 newly made screw locations to secure it. Seems to be holding up fine.
Old Jun 29, 2022 | 09:17 PM
bad venge's Avatar
bad venge
Section Moderator
I believe I have a set of grey and a set of black panels
Old Jun 30, 2022 | 10:22 AM
Hero6's Avatar
Hero6
Currently the fix I did seems to be working fine, but I will keep you in mind if it fails to hold up. Thank You
