1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
What is the easiest way to hook-up an air/fuel ratio guage in a 97 Avenger
Old 03-03-2006, 11:08 PM
Viperlookalike's Avatar
Viperlookalike
Viperlookalike is offline
Default What is the easiest way to hook-up an air/fuel ratio guage in a 97 Avenger
What is the easiest way to hook up an air\fuel ratio guage into a 97 avenger with a 420a, I know where I want to mount it but don't know what wire to tap into or where to tap into it?? Any feedback would be greatly appreciated...
Old 03-05-2006, 03:28 PM
BlkAveng97's Avatar
BlkAveng97
BlkAveng97 is offline
Default RE: What is the easiest way to hook-up an air/fuel ratio guage in a 97 Avenger
You need to find a wire diagram for the Emission system and tap in to the pre cat 02 sensor. Im not sure what color wire it is however it gonna be thewire that sends signal to the pcm. Hope this helps
Old 03-09-2006, 03:33 AM
daytonairoc's Avatar
daytonairoc
daytonairoc is offline
why do you need this? is it just for looks? if so it dosnt matter... but if you want to get actual resulst you need to get a wideband kit and drill into your exhaust. that way you can have an eaiser time tuning your car
Quick Reply: What is the easiest way to hook-up an air/fuel ratio guage in a 97 Avenger
