1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
console
Old May 5, 2006 | 05:30 PM
95_Avenger's Avatar
95_Avenger
Default console
i have heard that you can change out the avenger counsil with a eclipse coulsil i was wadering how hard it is to do it and how it looks? Sorry about the ****ty spelling.
Old May 5, 2006 | 05:38 PM
DevilsReject's Avatar
DevilsReject
Noob Assassin
Default RE: counsual
It's console for future reference
It is possible, and while it takes a little effort, it looks awesome! silvercoupe97, our Avenger section moderator, has done this swap. His car is the sweet sleeper of a ride.
You can view his console picture HERE
That's his cardomain site, and the pictures are located about 2/3's of the way down the page.
Old May 5, 2006 | 09:14 PM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
Thanks for the comment DR and you beat me to it
Yup, you sure can, it was a pretty easy swap also. The only things that you need to know is that you're going to need to get the 95-99 stock radio brackets and will have to get the correct shifter bezel to match what you have. You may find some on ebay in the Eclipse section or...I say, just go to a junkyard and look for one.
This swap is a panel for panel swap and everything lines up so it's not hard at all.
Old May 30, 2006 | 11:56 AM
element000101's Avatar
element000101
John, im looking on doing the same thing, what u mean is, if im going to do the swap i have to re-install my radio, and if possible where can i find the center console, and shifter bezel, u think u caqn help me out, u did before...
Thanks,
Frank
Old May 30, 2006 | 12:08 PM
silvercoupe97
Uber Moderator
You won't have to "reinstall" the wires or anything like that, just remove the wireharness from the radio, but you will need to get either the Eclipse factory radio cage and "pocket" or just get an aftermarket radio install kit for the 95-99 Eclipse. Assuming that you have an aftermarket radio, if not...you will have to make your own bezel. The Avenger radio is a din and a half while the Eclipses are a double din radio slot(s).
The panels are the same except for the the shifter area. The shifter bezel need to be replaced. If you look at my pics, you can clearly see that the shifter bezel is wider than the Avenger/Sebring shifter bezel..plus, you will have to get the cupholder/ashtray component, since that piece pops out. Check your local junkyard for 95-99 Eclipses or look on ebay for them, they're not really that hard to find...the color that you want may be though (black/tan/gray).
Old May 30, 2006 | 12:20 PM
element000101
hey john i just looked on ebay and will these fit my car
CONSOLE= Item Number (8069385146)
PODS= Item Number (8070413166)
can u just take a look for me to see if they will fit my car...thanks john
Thanks,
Frank
Old May 31, 2006 | 07:47 AM
silvercoupe97
Uber Moderator
I don't know the part numbers Frank, just what they look like and make, model, year that they came out of
That's what it should look like. There's more in my CarDomain link above my Sig pic.
John
Old May 31, 2006 | 10:52 AM
element000101
Thanks, the one im looking at is made for the manual eclipse, and my car is automatic, is there a difference between sizes in the bezel...im guessing the pods will work since its from a eclipse, so it should fit since our interiors like the same (I had an eclipse)
Old May 31, 2006 | 10:54 AM
element000101
o0o my bad john the part numbers are from www.ebay.com my bad i should of told you, its not the part number from the actual piece...My bad
silvercoupe97
Uber Moderator
It will fit. The only thing is that you will need an automatic shifter bezel from an automatic Eclipse. The one I have in the pic is an auto bezel and there was a huge difference with the size.
