1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
1999 Avenger ES stuck in 2nd gear
Old Jul 6, 2006 | 03:45 PM
babygirl71's Avatar
babygirl71
Default 1999 Avenger ES stuck in 2nd gear
Driving home last week my car wouldn't come out of 2nd gear. I've changed the
fluids etc....nothings worked. Any ideas??
Old Jul 6, 2006 | 06:12 PM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
Default RE: 1999 Avenger ES stuck in 2nd gear
Welcome to DF babygirl.
What kind of fluid did you put in? Check the fluid level with the car running to get an accurate reading on the stick.
Since it's still in limp mode even after the fluid change, I would take it to a garage. Limp mode is activated because there's usually something wrong with the tranny and if changing the fluid doesn't help even the slightest bit, it could mean big money.
Old Jul 6, 2006 | 06:21 PM
babygirl71's Avatar
babygirl71
I'm assuming it was tranny fluid, also changed the speed sensor as I was told that might be it.
My boyfriend is/was driving it and he's trying to take care of it.
ORIGINAL: silvercoupe97
Old Jul 7, 2006 | 03:19 AM
Georgiaboy6170's Avatar
Georgiaboy6170
Hey babyGirl - is your speedometer working? My speedometer stopped working when my car (95 Avenger) was stuck in second gear - I just got repaired this week- was just a speed sensor - repair charge was under $100 Good luck with yours and make sure you get at least 2 opinions - the first place I went to told me that I needed a new transmission!![sm=signs003.gif]Hmmm I see now in your post above that you've already changed the speed sensor...sorry!
