1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
How-to: Remote key fob programming
Old Mar 23, 2011 | 02:03 PM
  #21
mdmiller's Avatar
mdmiller
Yes, I used my voltmeter to test pin 4 and where I tried grounding to the chassis.
Old Jul 19, 2011 | 03:06 PM
  #22
peonu2's Avatar
peonu2
Default 2008 dakota
Originally Posted by silvercoupe97
This is the same process that I use/used to reprogram my stock key fob. It's word for word on how to do this on your Avenger/Sebring. Since it's not in my own words I used quotes and it was written (or copied) by several folks with either 2G Eclipses/Talons or Avenger/Sebrings, I give those folks kudos...you know who you are.
hi does anyone know if this works on a 2008 dakota i have one key but want to have 2 tks
Old Jul 19, 2011 | 03:57 PM
  #23
jasonw's Avatar
jasonw
Site Moderator
Peonu2, take a peak at your other post in the Durango section. I moved it to the 3rd Gen Dakota section, you'll get better help there for Dakotas.
Old Nov 11, 2011 | 09:49 PM
  #24
Rompetoto's Avatar
Rompetoto
I lost the copys to my car 09 charger will this work if i buy a set from ebay or do i need the original key my email is rdptrix@aol.com thanks in advance
Old Nov 11, 2011 | 09:54 PM
  #25
Rompetoto's Avatar
Rompetoto
Will this work if you lost both of the keys for 09 charger i was planing to buy a set from ebay please email me at rdptrix@aol.com
Old Nov 11, 2011 | 10:29 PM
  #26
bad venge's Avatar
bad venge
Section Moderator
I DOUBT this will work for your car ... I'd ASK in the proper section for your vehicle
Old Mar 2, 2012 | 02:09 AM
  #27
tbyrd2012's Avatar
tbyrd2012
Default Re programming new remote
So this method will work to program a new second remote. All the places that sell replacement remotes say you need 2 working remotes?
This is for a 2008 Avenger.
Old Mar 2, 2012 | 04:08 PM
  #28
bad venge's Avatar
bad venge
Section Moderator
AGAIN this is the 1st gen avenger, I'd ask in the second gen Avenger section
Old Apr 11, 2012 | 09:20 PM
  #29
timallen2k's Avatar
timallen2k
Default 2005 dakota
Anyone have the way to program a 2005 dakota? this guide doesnt work. I dont have a pin 1, and if you look for the blue wire I have it on pin 3. I cannot get it to program a new fob.
Old Apr 11, 2012 | 09:32 PM
  #30
bad venge's Avatar
bad venge
Section Moderator
Again ASK IN THE DAKOTA SECTION ...
